Bell housing alignment
Discussion in '1947-1954' started by skiter1961, Feb 21, 2015.
  1. skiter1961
    skiter1961 Member
    California
    I have a 1950 3100 I am putting a T5 in I am having an issue with the alignment the dowels look to be 3/8 inch dia. Does anyone know if they make offset dowels that are 3/8 dia. I have a235 in the truck Thanks for any help you guys might be able to give. And if they sell them where tks
  2. ol' chebby
    With the Hotrodworks adapter they say to drill the 4 mounting holes to 1/2". This may be the problem. Check my tech thread on this.
  3. ronaldg
    ronaldg Member
    adaptor plate
    skitter check this out it may helphttp://www.langdonsstovebolt.com/parts-faqs/transmission-adapter-56-3001/
  4. wolffcub
    wolffcub Member
    Im also doing the t5 conversion. I'm wondering what dowels your actually asking about. If your changing out a bell housing yes but to do the t5 you only need to drill out the holes to 1/2" and bolt the trans to the old bell. Other minor changes need to be made to the t5 input shaft but im sure you already got that handled.
  5. Bill Hanlon
  6. wolffcub
    wolffcub Member
    the plate in toms link is for installing an auto trans.
  7. ol' chebby
    If by dowel pins you mean some long bolts with the heads cut off to aid with alignment, you may have the wrong size...
  8. skiter1961
    skiter1961 Member
    California
    Dowel pins
    What I should have explained is that there are 3/8 in dowel pins on my 235 engine With the old sm420 transmission it was not a issue that there was over .008 out of alignment issue but with the t 5 rebuilt it needs to be under .005 so I am trying to center it but I find no offset dowel pins of that diameter If the bell housing was not off It would have been a very easy process I can only hope the torque tube replacement will go easier. But thanks for all the feedback.
  9. Bill Hanlon
    Summit Racing lists McLeod offset dowels in 3/8" by 1.25" Summit part number MCL-8707-22, 3/8" by 1" MCL-8707-21 and 3/8" x 3/4" MCL-8707-20. If they wont work a good machine shop should be able to make some for you.
