Is this the way it's supposed to be - 235 cu in
Discussion in 'Performance, Engine, and Transmission' started by cmkruse, Dec 2, 2014.
  1. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Went to preadjust the valves on this spare engine before installation and I think the center oil pipe might be broken. I'm not that familiar with 235 internals but this doesn't look anything like a 216 I have. Any help appreciated. Oh, it's a 55 engine.:confused:
  2. sleepindawg
    sleepindawg Member
    Topeka, Ks
    Mine curves a little more up and around the rocker shaft and it is pinched like yours as well. I did read something some where that said the pinch was used to "spray" oil. Just letting you know what mine looks like. I don't know much about these engines either.
  3. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Oil Tube
    Thanks for the response. Yea, I think I saw a post that indicated the same but I think mine was cut or broken. I left it alone an put the cover back on after adjusting the valves . It was running before so I guess It will keep on going!!!:D
