SM420 PTO cover
Discussion in '1947-1954' started by Bill Hanlon, May 4, 2015.
  1. Bill Hanlon
    Anyone know where I can buy a PTO cover gasket for an SM420 transmission in my '52 GMC 150? Mine is leaking a bit.
    Tried Classic Parts and Novak's web sites with no luck.
    Rock Auto lists Felpro TS5100 but doesn't say if it is for a 3 speed or 4 speed. Picture looks to be for a 4 speed.
    Felpro TS5100
  3. ccharr
    Couldn't you just make your own gasket or use try using some Permatex 81160 High-Temp Red RTV Silicone Gasket for it? The guys replacing the rear-end pumpkin cover use just a silicone gasket maker. That is what they used on my 342/1 when they put it in.
  4. jackson
    jackson Member
    Gold Bar, Wa.
    Try Novac.
    Gaskets
    Me , I'd scrape & wire brush it HOSPITAL CLEAN then lay a thin 3/16" bead of Permatex " The Right Stuff " ~ you have to try this newfangled stuff to believe it ~ nothing else comes close .
    I use it everywhere now and never a leak weep nor seep ~ that's saying something when it comes to 1930's Tech engines .
