Jaguar IFS
Discussion in '1947-1954' started by Guest5979, May 17, 2015.
  1. Guest5979
    Guest5979 Guest
    Has anyone taken out a jaguar IFS just wondering how hard is it or not going to be since will not be using any air tools sockets and wrenching .old school in the bone yard
    Also I have no plans on power steering will this be an issue with a front IFS that has it??
    Again thanks Robert
  2. Zig
    Well, you win!!!
    I guess you must have stumped the experts here!
    Not that I would ever want to put on a jaguar front end, but I of course was interested to see how this would work.
    Sometimes you just have to dive in and go for it.
    Let us know your progress!
  3. 52wasp
    52wasp Member
    Wilton, New Hampshire
    It's because there are no PICTURES Zig (you know how you are about that).
    Funny, I read Jaguar IRS here, not IFS. Power steering box without the pump probably not going to work correctly. Think about when you steer a PS car with the engine not running.
  4. Guest5979
    Guest5979 Guest
    Doing my homework tons of info also Phil has been giving me a ton of info on installation hope he post pics of his truck and IFS seems to be way cheaper than mustang II front end so once I get into it I will post some pics tip than back to more sanding on fenders.
    Robert
  5. e015475
    e015475 Member
    Show Low AZ
    Here's a '49 GMC with a Jag IFS and IRS (getting metal work done) [​IMG]
    A photo of the IFS - bolted in using Jag rubber mounts
    Another photo of the IFS- no springs, bags coming and it sitting on a piece of all-thread at factory Jag XJ6 ride height
    And if you're confused between IFS and IRS, here's a Jag IRS in that same truck-
    Probably going to not use the Jag sheetmetal cage and will suspend the IRS center section directly between the frame sides. 3.54 with limited slip, inboard brakes. IRS is on trailing arms with bags (but not yet) On all-thread at the stock Jag height. Should be a couple inches off the ground with the bags aired out. No c-notch. Wheels clear bed sides, so I'm not planning a tub, but the tires are line on line with the fender lip, so I need to start planning on how to widen the fenders.
    Just for fun here's the 58? Caddy Eldorado steering wheel. Floor is still a little rough - starting to fab firewall doghouse and trans cover
    Phil
  6. Guest5979
    Guest5979 Guest
    no pics
    thanks for posting Phil but the pics didn't show up.
    Robert
  7. e015475
    e015475 Member
    Show Low AZ
    Robert -Here's some photos of how it is installed in the truck.
    The front mounts are hung off a crossbar that pick up the Jag 'doughnuts' in the frame horn.
    The cross bar bolts on to the front frame horns- keep in mind this is just mocked-up so there will be three grade 8 bolts holding the plate the frame
    This is the top of the spring pocket in the cross-member on the driver's side. You can see the rear mount with three bolts to the frame rail on the left side of the photo
    Neto84 likes this.
  8. Zig
    Phil, this just ain't fair. You keep showing us the Emperor's New Clothes.
    I'm not sure how good you think our imagination is, but we'd rather see pictures! ;)
  9. e015475
    e015475 Member
    Show Low AZ
    Robert/Latroca said the same thing - I've logged in with a couple different computers and they pop up fine for me. You can't see any photos?
  10. Bill Hanlon
    I can't se them either.
  11. e015475
    e015475 Member
    Show Low AZ
    Ok - let me try on another server with IE
    The truck in the shop getting metal work done -
    The chassis with the Jag IFS before the body went on (aluminum 5.3 & T5)
    The support bracket for the front of the Jag IFS-
    The bottom of the IFS bracket-
    The side of the IFS front bracket-
    The rear bracket for the IFS looking at the driver's side spindle/rotor
    The Cadillac steering wheel and chopped up firewall-
    The IRS for this truck-ditching the cage and will be supporting the center with a single square tube of steel on urethane mounts at the frame rails
    Wazza1972 likes this.
  12. Zig
    Oh HECK YES!!!
    And a GMC no less!!! I'm loving it!
    Thanks for the extra effort to post the photos! :cool:
    Like several on here, I look forward to seeing the finished product probably as much as you do!
  13. Guest5979
    Guest5979 Guest
    Pics
    Thanks Phil
    The pics are awesome and very helpful now you have me thinking about an IRS in my truck.
    Robert
  14. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    THAT IS COOL!!! What tire wheel combo are you using? Plans for fuel tank? I just installed a NoLimit tank in mine, plan to post it to my thread sometime soon.
  15. Guest5979
    Guest5979 Guest
    Fuel tank
    Please do LS3 we all need the ideas on options I myself removed fuel spout out of my cab too.
    Robert
    Neto84 likes this.
  16. e015475
    e015475 Member
    Show Low AZ
    Everything is just in the mock-up stage so don't know what I'm going to do for a fuel tank yet. Welded up the gas tank hole in the cab, so I guess I'm committed to putting it in back of the rear axle somehow.
    I'd like to keep the utility of bed of the truck and the idea of a filler cap in the bed floor isn't what I want. I'd like to keep the fender clean too, but there's some very slick gas caps in rear fenders out there.
    My preference is put the cap under a flip down license plate in the rear roll pan. I have a junk 67/68 Camaro tank where the filler neck looks about right so I think I'll try that first. If it works, they are only about $100 at the SoCal here. The downside is I'll have to bend over quite a bit to put gas in it -oh well.
    The wheels are Boss and 18" and the tires are BFG - the Jag takes the Chevy bolt pattern and a Ford lug nut. The tires come within a half inch of the bed in the back and are going to rub the fender - so I'm looking for ways to get more clearance. Narrowing the Jag IRS and tubbing the inside of the bed is a lot of work. Widening steel fenders is spendy. The 3" wider fiberglass fenders are too wide.
    Phil
  17. Guest5979
    Guest5979 Guest
    Picking up a jag ifs so question is I have a 1972 k5 blazer 6 lug rear end in truck and now want to convert to 5 lug so I can rotate tires is this an easy conversion?
  18. Guest5979
    Guest5979 Guest
    No ifs today
    I didn't buy the I F S due to a cut arm when they cut the horns off they cut deep into the lower arm so I passed it up but the guy was ok with the fact it was cut said no big deal he would just weld it up.no thanks
  19. Guest5979
    Guest5979 Guest
    Another pic
    Trying to get another pic
  20. vwnate1
    Smart move Robert ! .
    These old Jags litter the So. Cal. Pick-A-Part yards.....
