Swapping gas 350 into 6.2 diesel
Discussion in '1973-1987' started by UtChevy, Sep 19, 2000.
  1. UtChevy
    UtChevy Member
    Howdy, anybody ever swap a gas engine into a diesel? what parts need to be replaced ? any problems to watch out for? Anyone have any good info? Thanks.
  2. my64bowtie
    my64bowtie Member
    [font size=1" color="#FF0000]LAST EDITED ON Mar-02-01 AT 10:16 PM (CST)[/font][p]I personaly havent done this, but I do know that it is a real pain. First off, you have to have a complete 350. That includes brackets, pulleys and other stuff like that. But like I say, it is a really big pain.
  3. truckertommy
    truckertommy Member
    Chevy gas motor isn't a direct bolt up. An oldsmobile 350 or 455 is. The rear end ratio in a diesel is is a lot higher than w/ a gas. Suggest a change to a lower gear ratio
  4. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    Actually, 6.2 diesels and 350 gassers are direct swaps and use the same motor mounts and trans bolt pattern. You just need to get the wire harness, accessories, etc for the 350 and change the governor and torque converter on the transmission. The old 350 diesels ('78-'81) are different and use the Oldsmobile bolt pattern.
