87 Chevy Pickup wiring
Discussion in '1973-1987' started by Rambo, Jun 13, 2001.
  1. Rambo
    Rambo Member
    I need to know the firing pattern for the spark plug to the distributer cap. Please help. Thank you
  2. stepside
    stepside Member
    If it is a V-8 engine...the firing order is 1-8-4-3-6-5-7-2.....and all Chevy V-8's have the same firing order....on most of them...the #1 plug wire is located to the right rear of the distributor...at about 11:00 ....if you are looking at the distributor from the front of the truck!
    Allan
    stepside
  3. Craig
    Craig Guest
    Do you have a HEI cap or the small cap? The number one cylinder should be at the front on the left if I remember right.
    Craig Hager
    tech1@chevyduty.com
