Leaky heater core fixed, Thanks Nate
Discussion in '1947-1954' started by denisf, Jul 11, 2015.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Well that little can of Silver seal appears to have stopped the leak in heater core. Just as Nate suggested, I ran the truck for a good 30 minutes and the floor and windshield bone dry!
    Thanks Nate for sharing your wisdom!!!
    mobileortho likes this.
    Silver Seal
    You're welcome .
    Often the simplest ways are also the best .
    FWIW , the BIG THREE American car makers have been using this in the initial assembly for decades , it's that good .
  3. coonkka
    coonkka Member
    Kansas City KS
    gonna try it
    Well I'm gonna give it a try. Just installed brand new alum radiator so kinda scary.
  4. denisf
    denisf Member
    still misting
    Well no leak in cab but mists on windshield. Think I will replace the core.
  5. Redneck Packrat
    Redneck Packrat Member
    South Texas
    What radiator cap you got on it? If you have much pressure at all, these old systems will find the weakest point and leak. I've read they were designed to run no-pressure, and we used to run 'em with radiator caps half-on (loose but on) and they'd never barf, even overloaded with grain on the trip to town.
    I'm hearing a 4# cap is about as high a pressure as you wanna put on them.
  6. denisf
    denisf Member
    Thanks I am not sure there is no markings. I am going to order one to be sure. Denis
  7. denisf
    denisf Member
    I replaced the radiator cap with a 4# cap and no issues!
    Redneck Packrat likes this.
