Temperature gauge question
Discussion in '1947-1954' started by dorcutt, Jul 26, 2015.
  1. dorcutt
    dorcutt Member
    Keep the truck in VT
    Fan belt came off the other day and temperature gage almost pegged out. Now it won't come back to zero but does seem to work as I can see the clear effect of the thermostat opening at apr 180 degrees. It just won't come back to zero. Any thoughts ? The tube seems to be good and know apprentice kinks that I can see. Dave
    Gauge Fun
    There's a hollow coiled up thing inside the gauge proper , IIRC it's called a ' Bourden tube ' and it has a strip of teeth on it that connect tot he needle ~ sometimes the teeth slip when the gauge pegs and if you delicately take the gauge apart you can re set it .
    Worth a try as it's junk now , WORK GENTLY HERE .
  3. dorcutt
    dorcutt Member
    Thanks Nate, I know exactly what your talking about. I will try it. Dave
