1984 4x4 rears ???/
Discussion in '1973-1987' started by kw70pu, Jan 29, 2002.
  1. kw70pu
    kw70pu Member
    i have a 1984 1/2 ton 4x4 and was wondering if the rears from a 1985 fullsize 1/2 ton blazer will work on my truck. thanks for any help
  2. 83 4x4
    83 4x4 Member
    Yes, they will but make sure the gear ratio is the same that you have now or it won't work and you'll destroy your T-case or worse.
