Help! steering link component identification
Discussion in '1960-1966' started by drl911, Aug 15, 2015.
  1. drl911
    drl911 Member
    Help!
    I have taken on a project for someone who is in the middle of a '66 GMC pickup restoration. Problem is the first mechanic who started a power steering conversion can't be located or contacted.
    Things I know:
    Power steering unit mounted is 7802644L
    Pitman arm is 6272424
    Hubs are 6274263 and 6274264 (already converted to disc brakes)
    Things I need::confused:
    Tie Rods - from what year/model/part numbers?????
    Idler Arm / Bracket - from what year/model/part numbers?????
    I have literally checked 5 different idler arms at the local parts store and they all have too small tapered pin for the cross link.
    Thanks in advance!!!
    Dan
  2. Rich 5150 69
    Rich 5150 69 Member
    Nor Cal
    Dan I`m only guessing that you will need the complete cross link from any `73 to `87 c10 or suburban, grab the whole unit, you may have to enlarge the holes in the frame for it but thats all, sense you`ve taken over someone else`s project did the previous builder use a steering plate mount, if not the steering will never be right as it will turn sharper to one side and you can`t adjust it out?plus the frame will have a chance to crack without it...should look similar to the Early Classic enterprises unit shown below..
  3. coilover
    Speedway has taper tools, 7 degree and 10 degree, that you can ream the tapered hole to size. Be careful these tools cut FAST. Dirt trackers use them when converting from Ford/GM ball joints to the quick to replace Chrysler screw in joints. You could re-size the idler you have.
