Incomplete instructions
Discussion in '1947-1954' started by coilover, Aug 30, 2015.
  1. coilover
    Wife's washing machine stopped the spin dry cycle so I did a search and it said either the shaft rag joint or the clutch was bad. Watched a repair video and then jumped into the ring. Where the instructions said to remove washer cabinet (a real bummer) to access the water pump and motor I immediately saw the instructions were for people that don't own a plasma cutter. The water pump is TIGHT against the rear of the cabinet but 30 seconds with the plasma and all is completely accessible. I wonder if I should send an instruction amendment to Whirpool?
  2. 52wasp
    52wasp Member
    Wilton, New Hampshire
    nicely done
    Evan,
    Having spent a LOT of quality time of late with the plasma cutter... I can say I laughed out loud at your solution to the problem at hand. I hope you don't take offense if I refer to it as "Yankee ingenuity".
  3. Zig
    Great solution! Pop rivet a piano hinge across the top for easy access next time. ;)
  4. Bill Hanlon
    Enough fun Evan. Did you get it working again?
  5. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    It's probably down for louvers and custom paint. If it was the dryer, I'd say paint some flames on it.:D
