Installing a C-Notch
Discussion in '1947-1954' started by Ricos54, Jan 7, 2014.
  1. Zig
    A-L-L that prep work is paying off! Obviously, we can't wait to see it all together as well!
  2. Ricos54
    Ricos54 Member
    CA
    Thanks Zig, yes all that hard work and months of body work definitely paid off. Glad I took my time and didn't rush it. Should be painting more of the truck tomorrow. Today I decided to start on the wood floor and stain it. I'm staying it a ebony. ;)
    Guest5979 likes this.
  3. Guest5979
    Guest5979 Guest
  4. Guest5979
    Guest5979 Guest
    awesome job on your build I learned a lot as well
    Robert
  5. Ricos54
    Ricos54 Member
    CA
    Thank you Robert
    Painted more last night
    [​IMG][​IMG]
    All that long hard work is paying off now .
  7. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Man, that is some straight, shiny, sheet metal! Keep us updated!
    Steve.
  8. Ricos54
    Ricos54 Member
    CA
    After 3 long months and the painter having to reshoot my entire truck over again, it's finally starting to come home. I really like the new color. Been working on it for a couple weeks. Hoping to have the truck together the beginning of the new year. I'm installing the glass this weekend and also started on the wiring
  9. Ricos54
    Ricos54 Member
    CA
    The day I picked up the cab and bed
    A few pictures of the new paint
  10. Zig
    That is absolutely beautiful! Thanks for the photo update!!!
    What mat are you using inside your cab?
  11. Ricos54
    Ricos54 Member
    CA
    Thanks Zig. That is pipe insulation from Lowes, it has a sticky back so it sticks to metal pretty easy. The only problem I had is I undercoated the inside of the cab with the rubberized stuff so I had to use 3m glue to make it stick. I didn't use any undercoating where the headliner go's so I didn't need any glue for that, stuck really good without anything. :D
    Zig likes this.
  12. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Wow, Rico, you can sure do fantastic body work! Those fenders, hood, all of it, look flawless! Thanks for the update.
    I'm jealous now...
    Steve.
  13. Mike1951
    Mike1951 Member
    Osawatomie, KS
    Rico
    What color is that? Man it looks like a million bucks
    Papy
  14. Ricos54
    Ricos54 Member
    CA
    Thank you Steve, can't tell you how many times I told myself how sick of sanding I was. Never seemed like it would ever end, but now I'm glad I stuck with it.
    Installed my glass today the back glass went fine, but when we got to the front it did not want to go in, it was like the glass was to big. I think it needs to be trimmed, my friend is going to have another guy come over and look at it. So I should know in another week on that.
    Zig likes this.
  15. Zig
    Thanks! I need to do this~
  16. Ricos54
    Ricos54 Member
    CA
    Thanks Papy
    It's a Dark Metallic Grey which has lots of metallic's and pearl's in it to give it a translucent look so it will change color's.
  17. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Thanks for the pictures! Very nice.
  18. Ricos54
    Ricos54 Member
    CA
  19. Ricos54
    Ricos54 Member
    CA
    All the wiring is almost done and AC, wipers hook up inside. I ran weather packs and a bulkhead for the wiring. Installed jute and Bentley carpet.
    I installed a lock up for my 700r4 and the setup was so long I had to fab a bracket so the setup with my gauge setup for the mechanical drive would be on the side away from the proportional valve on my brakes
  20. Ricos54
    Ricos54 Member
    CA
    Also finish the back piece in the cab from rod doors and had it upholstered and installed my seat belts
