Tune Up & Valve Adjustment
Discussion in '1947-1954' started by vwnate1, Nov 2, 2011.
  1. vwnate1
    O.K. , I got a query for my older posts on this , anyone know where they went ? :confused: .
    Please post links to them both, Deve's most excellent valve adjust page and hopefully , some of my old 216/235/261 tune up How-To's .
    TIA ,
  2. Larrys 48
    Larrys 48 Member
    Spokane, WA
    That's One
    Now , where did all my detailed how to tune an InLine 6 Banger posts go ? .
    Thanx ! .
  4. ol' chebby
    Nate, click on your screen name at the top right in blue. Open your page and click on statistics. C lick on "Find all threads started by VW Nate. Find your old post and copy and paste on a new thread, or just make a comment on the old thread and it will pop back up.
    Thanx Russ
    But ;
    I tried that and didn't find it..... :confused: .
    I know you alls are WAYYY better than I at finding this stuff .
    I keep most of my info inside my empty head , no brains up there so lotsa room for Tech Specs. :p .
  6. RidesWithYah
    RidesWithYah Member
    Lexington KY
  7. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Deve has rearranged his site.
    Hot valve lash procedure is now here.
    My question is COLD, as in prepping to fire a fresh rebuilt (or long stored) motor.
    Life got in the way of getting the old GMC running again, but I had a quick look at the valve lash by turning it over a quarter turn at a time on the stand.
    Cylinder Intake Exhaust
    1 18 22
    2 20 25
    3 10 24
    4 16 41
    5 20 23
    6 16 28
    Is that close enough to let it fly and then adjust them hot,
    or what should I be targeting cold?
    Thanks, y'all.
  8. Bill Hanlon
    After doing a valve job on my 228 two years ago, I set intakes to 0.012" cold (not running) and exhaust to 0.020" cold. After starting and warming up, I reset to those same values. After a tank of gas, I hot adjusted once again to the same values. Worked for me.
