Just a little rough
Discussion in '1947-1954' started by coilover, Jul 24, 2015.
  1. coilover
    Customers somewhat rare 68 Mustang big block convertible didn't have much good left on it so it's just about is being built from scratch. Will show progress reports. Probably will be a New Years present.
  2. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Just a wee bit of work left!
  3. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Thanks for posting these photo's.
    When you see these cars taken down this far its easy to understand why doors pop open when horsepower and sticky tires are combined.
    Is this one going to be bone stock or are some upgrades included?
    _____
    John
  4. coilover
    A few upgrades but nothing radical. Biggest is using a Mustang II front to get rid of the awful coil spring on top of upper A-frame and the even worse the ram assist power steering. Will first build frame rails and frame connectors to give a solid platform to work from. It's hard to shim panels in the correct position when they are attached to air.
  5. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Excellent upgrade. The Chevy II's and Mustangs..... shock towers are just a bad design.
  6. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Unibody cars, especially, convertibles, just seem flimsy.
    Curious, a big-block Ford with 4 lug wheels.
    I'm thinking this car must have sentimental value? Otherwise couldn't the guy find a better one, rather than pay you to build a basically "new" one?
  7. Zig
    Up for the challenge~
    Seriously! Good thing nothing scares Evan.
    Wowie - Zowie
    These were cheaply designed and built cars when new , I can only imagine what this is going to co$t .
    To - day I was Junkyarding ( !YES! I found my fuel tank and air cleaner !) and spotted a '66 Mustang and a '63 Falcon Ranchero in the same yard .
    Amazing .
  9. coilover
    Darn Paul, you are sharp eyed. The 4 lug rear is a "moving around" rear end used while sandblasting to keep the grit out of the 9".
  10. coilover
    One month update:
    Has full frame now--front and rear heavy(3/16) sub frames and 1/4" tube connectors.
    MII IFS installed
    Ladder bar/coils/Panard bar rear mount brackets in place.
    Major panels like cowl/quarters/front inner fenders, etc. in place
    Bracing run to secure panel position as rusted areas are replaced
    Door openings in proper position
    Inner and out rockers in place (critical on a convertible)
    Now the work begins; will visit next month
  11. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Nice foundation. Thanks for the update.
    _____
    John
  12. ccharr
    Thanks for the update Evan.
  13. vwnate1
    Wow .
    One can only imagine how much work will be involved by the end .
    I wish I could afford this much detail work done to my beloved and *MUCH* better condition 1959 Nash Metropolitan Fixed head Coupe .
    Are you still on projected new year's finishing Evan ? .
  14. coilover
    Nate,
    My guess is that it will be a complete running driving car by new years but being a unibody the finishing details can bite one in the butt time wise sometimes. You can't adjust alignment and gaps with shims like on a body on frame car so corrections are harder.
  15. coilover
    It's past New Years and not close to being ready but for a change not our fault. Customer had us switch to his 65 GTO which he bought at a Barrett-Jackson and was a beauty on the outside but made strictly to sell on the hidden areas. Now back on Mustang and it's starting to resemble a car again. There are no aftermarket inner rear fenders for a convertible so note the massaged tops---courtesy of a ball peen hammer. When top mechanism for sure clears and works then tops will be cut off and smooth plate used. All the filler around the front clip is over factory stamping wrinkles; the owner wants the underside as smooth as the outside. IMG_4033.JPG IMG_4035.JPG IMG_4036.JPG IMG_4038.JPG IMG_4037.JPG
  16. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Shock tower delete... that's going to be one beautiful engine bay. Destined to be one of the nicest Mustangs ever built.
