Fuel pump install
Discussion in '1947-1954' started by Ed Wells, Mar 31, 2016.
  1. Ed Wells
    Ed Wells Member
    Hi All,
    I am trying to install a glass bowl fuel pump on my 51. I have been told that it is important that the cam be in the lowest position when I mount the pump (as I understand the lever on the fuel pump contacts the cam). I can see the cam through the hole in the block, and when I turn the crankshaft pulley I can see it rotate, but I have no idea what the lowest position is.
    Any help for this knucklehead newbie is greatly appreciated!
    Ed
  2. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Ed, welcome aboard. If the fuel pump is like other cam-lobe driven pumps, having the cam's pump lobe on it's baseline circle means you won't have to tighten the pump "onto" the cam lobe.
  3. Ed Wells
    Ed Wells Member
    Ok Thanks Mike. So, if I have the tall part of the lobe pointing up, then it sounds like the installation is easiest since the pump lever doesn't need to compress as I tighten the mounting bolts (is that correct?) Will I be able to tell if the lobe is pointing up by inserting a fingertip or screwdriver through the opening in the block as I turn the crank pulley? Thanks -
    Ed
