Temp gage
Discussion in '1947-1954' started by Guest5979, Apr 10, 2016.
  1. Guest5979
    Guest5979 Guest
    image.jpeg how do I remove the temp gage tube from the back of gage I don't won't to drill a huge hole in the firewall to feed it through if I can remove it from the gage itself than only a small hole in the firewall
    Thanks Robert
  2. Guest5979
    Guest5979 Guest
    I thought I would ask before I break it hate learning the hard way all the time
  3. Bill Hanlon
    If you remove the tube you'll let the magic out.
  4. Guest5979
    Guest5979 Guest
    So I guess that means I have to find another way to route the unit .I was hoping to remove tube from back of gage for a small hole to be drilled in firewall now I will look for other options maybe a under dash temp gage
  5. Zig
    It seems like I unfastened my line at the block, and pulled the whole thing through the hole in the dash.
    It's been a while, but I believe that's what I did?
  6. Guest5979
    Guest5979 Guest
  7. Guest5979
    Guest5979 Guest
    I don't have any holes for wires or cables yet and I didn't want to drill a hole the size of the temp sensor and bolt that holds it in the block so I will have to reroute the line
  8. Bill Hanlon
    Too pretty to cut. Maybe WiFi?
  9. coilover
    One of the venders, Jim Carter I think, will put any length capillary tube on a temp gauge. If you measure a route that would go in the side of the kick panel you could order one that length and keep the firewall tidy. We have run a/c lines like this so I know there is room.
  10. Ricos54
    Ricos54 Member
    CA
    As you know my firewall looks like yours, I ran everything through the floor plate above the transmission. Don't know if that's a option but did not want to drill holes where I spent hours making the firewall smooth.
  11. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Or... convert the gauge to an electric one... certainly more work, getting into the quad gauge cluster and all. But, then all you'll have is a single wire.
  12. Guest5979
    Guest5979 Guest
    I know what you mean Rico about all the time spent in getting the firewall smooth
    I want to keep all the wires out of site if possible
  13. Guest5979
    Guest5979 Guest
    That thought is being looked at right now as well
  14. 52wasp
    52wasp Member
    I can tell you it is a slippery slope... for me it was "I'll replace the Ammeter with a Voltmeter", but then I noticed the oil pressure only went to 30, realized the sending unit from a '53 gas tank wasn't going to read the same as from a 2000, and Temp only went to 220, and so on. You get the idea.
  15. Guest5979
    Guest5979 Guest
    No kidding on slippery slope don't want to burn up engine for one less hole in the firewall
    I will send JIM carter a email today see what ideas he Mayhave
    Thanks for input
    Robert
