Drag link install
Discussion in '1947-1954' started by Ed Wells, May 5, 2016.
  1. Ed Wells
    Ed Wells Member
    Hi All,
    I just received a new drag link with the springs and cups etc. It is the original style for my '51 3/4 ton.
    My question is when I attach it to the pitman arm and steering arm balls, how do I know how much to tighten down on the threaded end plugs? I am thinking that it should be tighten them all the way down onto the balls and then back them off a bit (maybe 1/2 a turn or so) before putting in the all-important cotter pins. Just not sure if that is correct. Thought I better check with the experts!
    Any help appreciated!
    Ed
    '51 GMC Maintenance Manual (same drag link) says to tighten snugly, then back off between 1/2 and one turn until cotter pin hole and the slot align. It also cautions against swapping hardware from one end to the other.
  3. Ed Wells
    Ed Wells Member
    Great, thanks Bill. I was thinking it would be something of the sort. Just wanted confirmation -
    Ed.
