54 Chevy 3100 horn button removal
Discussion in '1947-1954' started by Bushman, Sep 17, 2016.
  1. Bushman
    Bushman Member
    How is the horn button removed on 1954 chevy 3100.
    Pull the wire off the horn (or remove one battery cable) then just pop off the horn button. You might need to use a screwdriver to pry it off. Why disconnect the horn? So you won't wake up the neighbors.
  3. Bushman
    Bushman Member
    Thanks Bill wasn't sure if it turned to come off or pried up. Little screwdriver prying got it right off. Now I can paint it back to original. Thanks
