People don't realize that putting a Camaro or Corvette all aluminum LS engine in a factory or already built car removes a bunch of weight from the front and gives the car a tail down look. This was the in thing in the 50's along with Lakes Pipes and fuzzy dice hanging on the rear view mirror but is not the look wanted now. Only cure is different rate front springs. The Olds is on a slope but if you look at the top of tire to fender opening you can see it's nose up as is the Pontiac.
