Can it be done!
Discussion in 'General Chevy & GMC Pickups Talk' started by 77chevyman, Sep 17, 2014.
  1. 77chevyman
    77chevyman Member
    Windsor America the Beautiful
    How hard is it to put a 70 Cab on at 85 frame ?
  2. Ben@CPOA/TECH
    Ben@CPOA/TECH Member
    Kansas City, MO
    Its possible, from the little bit of research I have done. seems your front cab mounts might almost line up, but the rear cab mounts, as well as the bed mounts will need to be fabricated. also the rear axle section on the 73-87 frame has a big curve, where the earlier trucks are straight. So either needs body lift, or fabrication to frame or bed, to make it work.
  3. 77chevyman
    77chevyman Member
    What I have is a cab and Front clip from c50 .the chassis is 84 3/4 ton 4x4 . So flat bed would look good
  4. ClassyMate123
    ClassyMate123 Member
    have you managed to put on the cab to your '85 frame?
