throttle knob/cable on dash?
Discussion in '1947-1954' started by denisf, May 26, 2017.
  1. denisf
    denisf Member
    Colchester, CT/ Clermont, FL
    Successfully removed both throttle and choke cables. What is the purpose of the throttle knob? Mine is spring loaded I can rev engine and then it goes back to normal, much like depressing accelerator. Denis
    Mine wasn't spring loaded. I say wasn't because I removed it and repositioned the choke cable to the lower hole to make more room for the electric wiper motor I installed shortly after acquiring my GMC. The first 1/2" or so of choke cable pull on my Carter YF carb (not stock) just increases throttle opening without actually starting to close the choke butterfly.
  3. denisf
    denisf Member
    Interesting, still wonder why there is a throttle cable? Denis
  4. Bill Hanlon
    Cheap cruise control???
    For use with a PTO, optional with 4 speed SM420 tranny???
  5. coilover
    Often used for warm up on cold mornings and to check generator output. It should NOT go back in by itself. Have used hammer and dolly to CAREFULLY flatten the cable housing in one small spot till correct drag on the cable is obtained.
  6. denisf
    denisf Member
    That makes sense, thanks. Denis
  7. Robert B Burgess
    Robert B Burgess Member
    Ease of starting and also an early form of cruise control on the Open Road
    denisf likes this.
