Hello, My Name is...
Discussion in '1947-1954' started by RidesWithYah, Jan 10, 2011.
  1. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Tin Worms. My truck had 'em too. You have to get ALL of them, or they come back. My employer spreads Tin Worm eggs on the parking lot every winter. They are off-white, and crystalline in appearance. Like Goonies (I just typed Goonies), they get out of hand when you add water.
  2. RidesWithYah
    RidesWithYah Member
    Lexington KY
    $500 worth of Dynacorn sheet metal.
  3. RidesWithYah
    RidesWithYah Member
    Lexington KY
  4. RidesWithYah
    RidesWithYah Member
    Lexington KY
  5. 52wasp
    52wasp Member
    Just make sure when you are done, you properly rinse/flush EVERY seam, nook and cranny. Read up on the proper steps to neutralize the paint remover. You'll be glad you did later, after paint. Looking good!
  6. Zig
    Ahhh, a good case of patina!
    I’m so glad my truck was in such solid shape. I would have never been able to fix that much.
    Good luck!
  7. RidesWithYah
    RidesWithYah Member
    Lexington KY
  8. RidesWithYah
    RidesWithYah Member
    Lexington KY
  9. RidesWithYah
    RidesWithYah Member
    Lexington KY
  10. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Stopped at the shop yesterday to see progress in person, answer a few questions about preferences going forward, and pay on my tab.
    Bill for work on the cab so far is ~13 hours of labor at $45 per, plus a gallon of aircraft stripper... Total $655.
  11. cantdrivemall
    cantdrivemall Member
    Calif.
    You must love that cab,,,, ALOT.
    RidesWithYah likes this.
  12. DeadZoneTruckin
    DeadZoneTruckin Member
    I have seen guys fix cabs that were worse than that...
    The only thing that scares me is when you remove so much metal without welding in temporary X bracing to keep all the cab panels aligned....
    The chances of the doors ever fitting right again are slim to none.
  13. 52wasp
    52wasp Member
    actually, its the perfect opportunity to make SURE the doors fit right. THEY become the temporary bracing, and establish the door opening- gaps and all.
    Zig and RidesWithYah like this.
  14. RidesWithYah
    RidesWithYah Member
    Lexington KY
    A little sentimentality for the cab, maybe - I have had it over 30 years, and it's only original once.
    But also, there aren't many in better shape around here.
    My body guy says it's "nice" compared to the last one he did...
    Appreciate the feedback, though -
    I didn't really know what to expect in terms of costs, so I'll continue to update the hours and the tab as it progresses.
    Maybe it will help someone else plan;
    and if things start to look out of whack, please let me know. :)
  15. 50 Chevy LS3
    50 Chevy LS3 Member
    Indiana
    Yeah, those guys out west have it made. My cab was as bad. Maybe worse.
    Steve.
  16. RidesWithYah
    RidesWithYah Member
    Lexington KY
    IMG_1854.JPG IMG_1855.JPG IMG_1856.JPG IMG_1857.JPG IMG_1858.JPG IMG_1859.JPG
  17. Zig
    Wow!
    Wet, you have a gas pedal, put that cab on and drive it!
  18. vwnate1
  19. RidesWithYah
    RidesWithYah Member
    Lexington KY
  20. Lakeroadster
    Lakeroadster Member
    Central Colorado
    Wow... lot's of work. Looking good, I bet your stoked to see it coming together.
    What size and type of wire are you using? Looks like it's burning through the patch panel primer well.
    ____
    John
