carb rebuild
Discussion in '1973-1987' started by nerfherder78, Jan 7, 2004.
  1. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    I've been looking into rebuilding the carbuerator on my truck, so I emailed a company called carbs only for info/ a kit. Only they told me they couldn't find a rebuild kit for my carb (17083502) even though they had the carb # listed, and that not even AC Delco makes a kit for it. x( They suggested that they might be able to piece together a kit with bulk parts if I send it to them, but they're about four hundred miles away.
    I also looked at a Edelbrock replacement carb, but they also didn't list one for the carb # either.
    Any suggestions on what should I do? Is there another carb I can use for the 4.3L? Any help would be appreciated.
    Craig
  2. cowboy
    cowboy Member
    What kinda carb are you rebuilding?
    cowboy
  3. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    it's the original rochester q-jet on my '85 vortec
  4. cowboy
    cowboy Member
    Have you tryied napa or shucks for the rebuild kit?
    cowboy
  5. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    I tried schucks and found a kit that was one digit off of mine, double checked the number on my carb and found I misread a 5 for a 3. That should help
    Thanks cowboy
