Leaking At Fuel Tank at Stem and Shut off Valve
Discussion in '1947-1954' started by mockoski, Aug 6, 2018.
  1. mockoski
    mockoski Member
    Good evening,
    Finally making my last connections, installed Fuel tank and inserted stem with Shut off valve underneath truck.
    I have been covered with Fuel for the last couple of days wondering what I am doing wrong.
    First, I installed the stem and valve without any thread sealant.. Second time I used Loctite Thread Sealant that was designed for Fuel, but I still get a beading of fuel coming down the stem..
    I then tighten the fitting 2 more times passed hand tight and afraid to over tighten the thing, and still get a drip. So what the hell am I missing here?
  2. Guest5979
    Guest5979 Guest
    Same thing happened to me when I replaced tank with a re pop tank in my 52 ,
    I was told the threads are off a bit on the re pop stuff.
    My fix was a radiator shop laid a pool of soider around the stim never had any fuel issues after that.
    Good luck
  3. mockoski
    mockoski Member
    How frustrating.. I would have hoped that the New Tank and the new stem/Valve that I purchased would have been tested to make sure this wouldn't happen.
    I will give them a call and see if they have any suggestions. I could see if I was using the old stem and valve might not line up exactly with the new tank threads, but since it is all new, then it should JUST WORK ! :)
    Thanks for sharing!
    James
    You'll find the re pop stuff often has serious defects, why I never suggest using re pop fuel tanks ~ the Chinese ones tend to have or develop, leaks around the pinch welds, this is a serious issue .
    Oddly, I tried to GIVE AWAY a nice cherry no rust clean undented California fuel tank for several YEARS before throwing it out .
  5. mockoski
    mockoski Member
    Yeah, I was trying to reuse my old tank, but it was to far gone.. So didn't have to much options where I am and purchased a new one at Classic Parts. Actually surprised it looks and feels like the real McCoy. It has to be something dumb that I am doing. I guess what fun is it if it isn't challenging and your not covered in fuel?
    Fair enough .
    I'm a Journeyman Mechanic so having gasoline run down my arms and into my armpits got old in 1972 or so.....
    Plus of course it's a CARCINOGENIC so have fun and freak out in the grease, oil and dirt but BE SAFE ~ .
  7. mockoski
    mockoski Member
    :) It only has to happen once before it gets old..
    Try doing it a few times a month for 40 years......
