'86 duel tank GMC Gas Gauge issue
Discussion in '1973-1987' started by Ken Hepting, Oct 10, 2018.
  1. Ken Hepting
    Ken Hepting Member
    When either tank is full fuel gauge reads 2/3 to 3/4 empty. Hence, I never know when reading "empty" really means, "EMPTY".
    I have replaced (1) tank sending unit, dash switch and fuel distributor-switching unit with no success.
    I suspect the gas gauge needs replacing since it indicates both tanks being faulty readings????
    Thanks for any input.
  2. nerfherder78
    nerfherder78 Member
    Fairfield, CA
    Most likely the resistor on the back of the gauge:
    The GM Fuel Gauge Mystery 1965 & Newer |
    Pull it off and see if the gauge moves.
    There are 5 different color resistors, you'll want to replace it with the same color:
    Lt blue-123 ohms
    green -89
    yellow-88
    orange-86
    blue black-81
    I had one fail on the back of my voltmeter last year, threw me off when I looked down and saw 0 volts. Managed to find a replacement after scouring the local wrecking yard.
