Wiper Blade Attachment Question
Discussion in '1947-1954' started by Zig, Jan 12, 2019.
  1. Zig
    I haven’t had any luck figuring out how the little clip connects the wiper arm to the wiper blade.
    Could someone take a photo of this connection please?
    Seeing how it’s hooked together would be a huge help.
    Thank you!
    It depends on the brand of blade and arm you have there, you may be trying to make the impossible happen, you should post pictures of what you've got .
  3. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Zig,
    Do you see the irony in your question to the forum, without pictures?
  4. coilover
    If your wiper arm has a "J" shape curve on the end you raise arm to maximum height and rotate arm into place (no locks IIRC). If the arm is straight with a small bump at the end you move the tiny tab on the top of the blade slot, slide blade in and release tab. Some of the replacements you can just slide blade on till you hear a click. Picture would help.
  5. Zig
    89157254-3175-4B80-A639-30863D0AC2D5.jpeg 2E96C7A5-D71F-4A4A-8364-3BD436F553F8.jpeg D5419F7A-E4FB-44E7-A616-49425FCEE9F4.jpeg Who knew? I’m terribly sorry I didn’t post photos. I just asked for one of yours (assembled) because I figured these would all be the same. #confused#
    (Especially since our host doesn’t have options to speak of)
    Anyway, always glad to oblige! #biggrin#
    Obviously I need a new spring for the arm...
    Twine & bailing wire.....
    I tolja these trucks were made for Farm Folks.....#rolleyes# .
  7. Bill Hanlon
    Zig:
    The wiper arms that our host sold 3-4 years ago (and probably now) look like the arm one below the red arm in your top picture above. The corresponding blade is not shown in any of your pictures. I was very disappointed in the "wimpyness" of these arms and blades when I bought a set 3-4 years ago. I installed the set anyway and they actually work pretty well with my electric wiper motor. Only problem is the blade WILL fall of the arm if you pull the arm away from the windshield.
  8. Zig
    Thanks, Bill!
    A picture is worth a thousand words, and what you posted gives me an idea to try.
    If it works, I’ll post a photo.
