Turn Signal Issue
Discussion in '1960-1966' started by Steven Hinkle, Apr 6, 2019.
  1. Steven Hinkle
    Steven Hinkle Member
    I am experiencing a problem with my front turn signals on my 66 C-10. They are acting weird an hopefully, someone has had this problem and can help me out. My rear turn signals work fine. For the front (both left and right), they do not blink with the head light switch off or on fully. However, they do work with the light switch in the middle or park lamp position. Could this be a switch issue? Any help would be greatly appreciated. Thank you.
  2. Woogeroo
    Woogeroo Member
    Seeing the USA in my Chevrolet!
    turn signal info., if you want to check those out:
    Tips, Tricks & Technical Stuff
    also you can check grounds for the blinker lights or add them if needed... and the headlight switch when it dies does a lot of strange things that will make you crazy trying to troubleshoot.
