54 Chevy engine Identification
Discussion in '1947-1954' started by Neto84, May 22, 2019.
  1. Neto84
    Neto84 Member
    hello
    I have a 1954 Chevy truck 3100 series straight 6 can many one help me ID what engine I have before I start rebuilding this what I found
    Block # 3769716 GM15
    CON 3B80
    Engine serial #?F0209b
    Head casting # 383648
  2. RidesWithYah
    RidesWithYah Member
    Lexington KY
    WELCOME!
    3769716 Block is 58-62 235, which means you have the late style block with full oil pressure.
    3836848 is the head that "belongs" with that block, and is the more desirable of the 235 heads.
    Don't jump into rebuilding until you know what you've got. What's the status?
    And yes, we want pictures.
  3. Neto84
    Neto84 Member
    So that means I would need parts for year 58-62 235 I’m new to all this first project car and I have never worked on cars other than basic oil change all this info is really helpful thanks
  4. Neto84
    Neto84 Member
    So that means I’m going to need 58-62 year 235 for the distributor fuel pump and alternator
  5. RidesWithYah
    RidesWithYah Member
    Lexington KY
    Unless you are going for 100% original (concourse restoration), this is actually great news.
    The motors look almost identical, but the newer six is much better in terms of both power and reliability.
    And yes, be sure to ask for the later parts. Most things are still relatively easy to find at your FLAPS (Friendly Local Auto Parts Store),
    or through rockauto.com, or our host.
    Lots of great folks here - always happy to help as you run into questions.
    Did I mention we love pictures? Would love to see your new project.
  6. Neto84
    Neto84 Member
    I just bought the truck it started up and when came to a stop it turns off my oil was super black decided to change and drop the pan to see what would I find
  7. Neto84
    Neto84 Member
    Truck on bed is when the guy first got it
  8. Neto84
    Neto84 Member
    Other pictures is what it looks like now
  9. Neto84
    Neto84 Member
    Yes eventually I’m going to rebuild the engine
  10. Neto84
    Neto84 Member
    I have a question if I put the gaskets I bought on my 54 but engine block is from 58-62 year will it leak oil # feo pro OS5041c
  11. Bill Hanlon
    Generator, not an alternator, on 58-62 Chevy 6 cylinder engines from the factory.
  12. Neto84
    Neto84 Member
    I have a 12v alternator now it was converted to 12v
  13. Guest5979
    Guest5979 Guest
    Welcome to the site looks like you have a great truck to start with
  14. Neto84
    Neto84 Member
  15. Neto84
    Neto84 Member
    58 235 Chevy straight 6 oil pan gaskets I got the right ones this time thanks for your help
  16. Neto84
    Neto84 Member
    Thanks can’t wait to have it running I actually got it for my wife it’s her truck Happy wife Happy life
  17. Guest5979
    Guest5979 Guest
    Truck looks good you have the right mind set just tweek a few things and drive it unlike myself been a part completely a couple of times they blow apart quick and go back together very slow and gets extremely expensive quick
