Picture from the rod that is connected to the carburetor
Discussion in '1947-1954' started by wokri, Jul 11, 2020.
  1. wokri
    wokri Member
    Germany
    vwnate1 likes this.
    Throttle linkage bellcrank .
    I don't have any pictures, sorry .
  3. wokri
    wokri Member
    Germany
    Hello Nate, the problem is completed. I've checked how the bellcrank will work.
    Wolfgang
    hopefully some one here will post some pictures.....
  5. jayz63
    jayz63 Member
    Albuquerque, NM
    I will post one in a few
  6. jayz63
    jayz63 Member
    Albuquerque, NM
    I think this is what your needing a picture of.
  7. Guest5979
    Guest5979 Guest
  8. Guest5979
    Guest5979 Guest
  9. wokri
    wokri Member
    Germany
    Hello, thank you for your pics.
    The last pic from LaTroca52 is the position where I fix my bellcrank and it will work.
    Wolfgang
    Note that there are multiple bell crank designs, early one are made of cast iron .
    One of La Trucka's images clearly shows the hole for the vertical rod is no longer round , this is the #1 cause of failure to return to proper idle speed....
    It's a fairly simple thing to have it welded up and re drilled then hardened .
    I used to find these throttle linkages at swap meets, the horizontal pickup one is slightly different shape than the passenger car one and is often incorrect .
