How fast should a 235 cui engine idle?
Discussion in '1947-1954' started by wokri, Aug 11, 2020.
  1. wokri
    wokri Member
    Germany
    Hello,
    how much Rpm should the engine idle run?
    Ask
    Wolfgang
    vwnate1 likes this.
    vwnate1 likes this.
  3. wokri
    wokri Member
    Germany
    Hello Bill,
    which side in the manual?
    Wolfgang
    vwnate1 likes this.
  4. Bill Hanlon
    vwnate1 likes this.
    In general, as long as there's oil weeping from the holes in the rockers you have sufficient idle speed .
    Slow idle uses far less ful and gives far better engine braking if you're actually driving your old truck .
    If not, up to 1,000 RPM's but I prefer 450~500 RPM unless the engine is worn out enough to foul the spark plugs ~ then you have to tune it more sharply and will be wanting at least 700RPM....
