How much oil do you fill in the differential housing
Discussion in '1947-1954' started by wokri, Sep 21, 2020.
  1. wokri
    wokri Member
    Germany
    Hello,
    how much oil do you fill into the differential housing. Its a Chevy 3600 build 1953.
    Ask
    Wolfgang
    Your 3600 would have the same differential as a 1952 GMC 150 series truck. This is taken from the 52 GMC Owner's manual. It should get you close. But the better answer is "until the oil falls out of the filler hole".
  3. wokri
    wokri Member
    Germany
    Ok, thank you Bill.
    Don't forget to add a magnet to the inner end of the filler plug ! .
  5. Chiro
    ^^^Nate, don't you mean the drain plug?
    Actually ;
    Because rare earth magnets are -so- cheap these days I put one on each plug .
    Interestingly, I get rougher looking SWARF on the drain plug, *much* finer on the filler plug .
    IMO, you cannot have too many magnets in the oil .
  7. Jeff Cherney
    Jeff Cherney Member
    This may sound like a dumb question but are there specific magnets for adding on plugs and how would you attach?
    GOOD QUESTION ! .
    I use the small disc shaped rare earth magnets from Harbor Freight, last time I bought them it was $6 for a tube of 5 .
    If you don't have a drain plug put one on the inside of the fill plug .
    Jeff Cherney likes this.
  9. Jeff Cherney
    Jeff Cherney Member
    Thanks, I’ll check that out!
  10. cochran
    cochran Member
    Denver
    Sorry to revive this old post, but do ya'll epoxy the magnet to the plug or just use the magic of magnet?
  11. vwnate1
    Never, EVER be sorry about asking a question ! .
    The magnet will hold itself in place .
    I like to remove the magnet for cleaning every year and slide it off the plug and use a clean white towel or paper napkin to get it as clean as I can .
    Don't forget to add a magnet to the engine's oil drain plug too ! .
  12. morabuffalo
    morabuffalo Member
    Albuquerque, NM
    Magnets can always help...a few years ago I was reminded of those little square lead like pieces put in gas tanks...can you guess what they were? I kinda recall seeing lots of ads back in the 50s or 60s that they were supposed to be for improving power and gas efficiency. I also remember actually putting those into gas tanks but had forgotten that, till I was trying to figure this puzzle out. Another puzzle and another memory recalled.
  13. vwnate1
    The magnets added to the fuel lines or placed around the spark plug wires are snake oil crap .
    A magnet inside any liquid device is a prophylactic measure that will help, even in modern and brandy new vehicles .
