Flywheel bolt safety locks
Discussion in '1947-1954' started by Al Downs, Mar 14, 2022.
  1. Al Downs
    Al Downs Member
    This is what I am looking for but I have no idea what they are called so it makes finding them tough. They are a type of lock to prevent the bolts from backing out on the flywheel of my 216.
    Does anyone know what they are called and a source to get them?
    vwnate1 likes this.
    Fredericksburg TX
    Depending on the year of your 216, you are looking for three of one of the last two items shown below.
    vwnate1 likes this.
  3. Al Downs
    Al Downs Member
    Any idea where they can be found?
    vwnate1 likes this.
    These are important, I remember a pristine 1954 Chevy 3100 that knocked loudly so the owner ass-u-med it had bad bearings, a Fireman I knew paid $800 for it in the late 1970's and added red loctite, was a very happy camper .
    Maybe try " chevsof the 40's " in Washington state ? .
    They used to have lots of stuff like this .
  5. Greg_H
    Greg_H Member
    I think there was a different style with hydra-matic as well. Definitely a need to seal the threads well.
  6. coilover
    These were used before LocTite was available. Use red as Nate suggested and the bolts WILL NOT back out unless heated. Think of the lock tabs as a whale oil lamp when LED's are now available
    vwnate1 likes this.
    Well said Evan .
  8. RidesWithYah
    RidesWithYah Member
    Lexington KY
    I would use Blue if you ever want to disassemble those again. Should be plenty to keep the bolts where they belong.
    The application of heat to the bolt heads will make them easily removable .
    Loose flywheel bolts was long a problem on these engines .
    RidesWithYah likes this.
