S10 offset rear end
Discussion in '1947-1954' started by Eddie Howard, Dec 30, 2025.
  1. Eddie Howard
    Eddie Howard Member
    Montevallo, AL (25 miles south of Birmingham, AL)
    Using a S10 4x4 rear end in 1950 Chevy truck stock frame with Chevy 350. Noticed drive shaft is offset to passenger side with axle housing centered on frame. Can i slide rear end over to center drive shaft and add a spacer to the passenger side wheel to match up space between frame and both rear wheels. Or if not please describe the best fix.
  2. 52wasp
    52wasp Member
    Wilton, New Hampshire
    Welcome to the Forum Eddie,
    As long as your pinion angle matches the angle of the engine/trans, and the engine/trans is pointing straight back, you shouldn't have an issue with the offset. Equal and opposite angles prevent vibrations.
    Add your location, there may be a fellow ADer nearby!
