Want a 350 instead of a 283?
Discussion in 'Truck Parts for Sale' started by Nic_Rebel450CA, Jan 20, 2004.
  1. Nic_Rebel450CA
    Nic_Rebel450CA Member
    Sacramento U.S.A.
    Just checking to see if there is anyone interested in getting rid of a 283 in favor of a 350. I have a really nice 350 in my truck that I am going to be pulling in favor of a big block, and I have a car that needs a small-block, but I dont want to use the 350. It is a light car, so I am thinking about building up a 283, or making a DZ302.
    My 350 is a 1988 Chevy 350 (possibly 4-bolt, not certain), edelbrock performer intake, mild (unknown) cam, Rochester Q-Jet Spreadbore carb (about a 650 CFM).
    I may be parting with the TH-400 transmission in the truck as well.
    Unless the 283 is in tip-top shape, I wont consider a straight trade, but I am not looking for much $$.
  2. Nic_Rebel450CA
    Sacramento U.S.A.
    *bump*
    come on, no one has even viewed this post
  3. ljw
    ljw Member
    tucson
    I don't understand why go the expense with a 350 already,but you can build a screamer of a 283 or 302 if you want to.Unless you're an engine builder,don't expect it to be cheap.Core 283 block are still plentiful just about anyplace,and I suggest using modern vortec heads.I had a motor built for my truck(383 stroker),which runs great with some modern tech.It's not like the antique heads didn't make any power,but not like this!
  4. Nic_Rebel450CA
    Sacramento U.S.A.
    Simply the fact that a 350 is not the engine that I want for the car. It does not have the powerband characteristics that I want for this light car. A 350 is not a universal perfect engine, though it is perfect for many setups.
    I do plan to build the engine myself, and am aware that it will still be expensive, however, it wont be any more expensive than building a strong 350. The shortblock of a 283 for the crank is about the same cost as buying a crank for a 350. The pistons, heads, intake, etc. are the same price as you can use the same parts as you would use for a 350.
    I actually needed to update this thread as I am no longer looking. I have a new addition to the family coming and will need to put this project on the back burner for a while.
  5. j0oftheworld
    j0oftheworld Member
    phx usa
    Where do you live?
    No 283 here but interested in a sbc.
    I'm in Phoenix AZ
    thx
  6. sevenpets0
    sevenpets0 Guest
    If you are still looking for a 283 I am pulling a great one from my 66 in about 6 weeks. It seems to have been rebuilt. It is a 2 barrel engine and does not smoke or leak. Runs great. I am looking for $200 out of it because it does not need a rebuild. Just a thought.
  7. Drel Pryn
    Drel Pryn Member
    $200 for a running 283? Sound ok where are you located?
  8. sevenpets0
    sevenpets0 Guest
    I am in the Kansas City area. Work email is Gpate1@hallmark.com Phone number is 913-484-4492.
