spring upgrade on 82 k10?
Discussion in 'General Chevy & GMC Pickups Talk' started by greme, Jan 28, 2004.
  1. greme
    greme Member
    can i upgrade my leaf springs to 3/4 springs? is this a major project or something fairly easy?
  2. 74X4Burb
    74X4Burb Member
    Fort Shaw U.S.A
    The front springs should bolt right in, and if you find the right length of rear spring(some are 52in some are 56in) they should bolt up pretty easily too.Karl
    ________
    IOS GAMES
  3. cowboy
    cowboy Member
    How much difference is there in the 1/2 ton springs and 3/4 ton springs? I have a 69 K10 that i would like to put 3/4ton or 1 ton springs under it and a 4 inch lift and run 33 inch tires.
    cowboy
  4. 74X4Burb
    74X4Burb Member
    Fort Shaw U.S.A
    from the factory I dont know how much difference there was an extra leaf or so in front, 2 or 3 extra in back,if you look at lift kits they'll give you the same thing for half and 3/4 ton trucks.Karl
    ________
    Medical marijuana news
  5. cowboy
    cowboy Member
    the lifts generaly have blocks for the rear unless you get a kit with rear springs but then they are the same for both.
    Cowboy
  6. greme
    greme Member
    i got my hands on 7 leaf rears and 3 leaf fronts. how much lift will those give? same as on a 3/4 ton truck?
  7. cowboy
    cowboy Member
    It probably will sit just the same as a 3/4 ton. You could get some longer shackles and lift it there and put about 2" blocks under the back. That will giver you probably about 3" total with the 3/4 ton springs.
    Cowboy
