Felt Inserts for ball joints
Discussion in '1955-1959' started by Danbau, May 18, 2006.
  1. Danbau
    Danbau Member
    West Lafayette USA
    I have a '57 chevy apache 4x4 and I need to find the felt inserts that hold grease in the ball joints.
    Any ideas where I can find them?
    Thanks,
    Dan
  2. rico_bob
    rico_bob Member
    Harrison USA
    Email me.
    My trucks:
    56 SWB Stepside Small Window
    57 SWB Stepside Big Window
    58 LWB Stepside 2B Ext. Cab
  3. Halfton57
    Halfton57 Member
    Kingsburg US
    I apologize in advance if I'm wrong but unless I'm mistaken, there wasn't an Apache pickup available until sometime after the 1957 model year. Also, I'm not all that familiar with the 4x4 but are you certain it has ball joints? I thought Chevy trucks of that vintage only had kingpins.
  4. Bill Hanlon
    Dan:
    Don't know if this will help, but if '57 Chevy 4wd front axle is the same as '57 GMC 4wd front axle which is a "GM F022" the felt seals that you are looking for are listed in the GMC Master Parts Book as:
    Quantity 4
    Part Number 2352858
    Seal - Front Axle Ball End Large
    Quantity 4
    Part Number 2352860
    Seal - Front Axle Ball End Small
    Looking at the drawing there only appears to be a total of 4 (upeer and lower half on each side), so I can't figure out the difference between "large" and "small". GMC used the same parts from '56 through at least '59 (my book only goes through 59).
  5. Bill Hanlon
