Disc brake help
Discussion in '1960-1966' started by aimless, Jul 27, 2006.
  1. aimless
    aimless Member
    Wichita
    I just recieved the complete front disc brake kit from Classic Parts of America for my '65 C-10. The rotors I recieved are 11" in diameter. Will a 15" wheel fit upon them without bumping the calipers? Also, how much will my offset change from the stock drum brake set up?
    Thanks for any and all help!
  2. aimless
    aimless Member
    Wichita
    I need to add that the conversion is going to take me from 6 to 5 lug and I am maintaining the stock height.
  3. dvalentine
    dvalentine Charter Member
    Sacramento
    I'm not positive about the Classic Parts kit. Other's kits, like one I used, push out the front tread width by about 1/2 inch per side.
    I used old school 15 inch chrome reverse rims on the front. It was tight, but they did fit.
    Finally, your wheel backspacing should not be an issue. There is a ton of room under the front fenders.
    DVal
  4. aimless
    aimless Member
    Wichita
    Okay, thanks. The kit actually came from CPP, and I just ordered them through CPA. The only reason I'm worried about back spacing is because I don't want the tires to stick out past the fenders, because that looks stupid. Currently, I'm running Eagle Racing 589s that are 15" x 10" wide and 3-1/4" backspacing, and tires that stand 27" tall and have 12" tread. They go right to the edge of the fenders.
  5. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    D Valintine Is Right, I Put On A 12 Inch Rotor And Had To Change My Steel Wheels To A 16 Inch But I Was Putting On An Old Style Solid Steel Wheel "gennie" So You Shouldnt Have Any Problems With Just A 11 Inch Rotor.
    66 Kustom
  6. aimless
    aimless Member
    Wichita
    Just FYI -
    I called CPP. My rotors will push my wheels out one inch. My wheels, I discovered, are not 15x10, but 15x8. Tires are 275/60R15s. I am going to go with the same wheels, but only in a 15x7, and I will get 255/70R15 tires. Little more height but a tad more narrow so as not to bump the fender. Thanks for your help guys! Let you know how it turns out!
