I.D. #'s for 1951 chevy
Discussion in '1947-1954' started by henry51, Sep 9, 2006.
  1. henry51
    henry51 Member
    Evansville IN
    Is the vin plate the only tag on these trucks? How do I decode my vin ? How do I find out what color it was, outside or inside?
  2. Kens 50 PU
    henry51, as far as i know the vin plate located on the drivers side door pillar is the only tag identifying your truck. There are a few websites out there that have vin decoders that will tell you about your truck. the easiest way is to post your vin # here and one of us can tell you pretty quickly. As far as knowing what color it was outside and inside, chevy cars used to have an additional plate (I think it was on the firewall) that used to give a paint # and a trim#, but the trucks didn't.
  3. henry51
    henry51 Member
    Evansville IN
    So is there any way to find out what color it was? V.I.N. srs 8jpl 1359
  4. Kens 50 PU
    henry51, the "8" means it was built in Atlanta, Ga, "JP" means that it is a 1951 series 3100 (1/2 ton), "L" means it was built in December, and the last 4 digits are the sequence number. As far as the color is concerned, look at certain areas if you decide to take the truck apart for clues as to its original color. Removing the hood emblem might show the dull, but original paint color, taking a headlight rim and bucket off might show the original paint, removing the center piece of the hood might show the original paint. If you remove a runningboard, the bottom portion of the rear fender might show you what the original paint color was. hope this helps.
  5. dngaspersich
    dngaspersich Member
    As for the original color, a good place to look is the firewall, original paint probably still there, or under one of them rubber grommets. Most are gonna be Forester Green as it was the standard color. Dave
  6. henry51
    henry51 Member
    Evansville IN
    I've found spots of real dull pale green (like army paint) under some dark green. Did they use green primer back then? Tha dark green is flaking like a repaint.
    What dose the SRS in front of the V.I.N. mean?
    Thanks for all your help
    Henry
  7. henry51
    henry51 Member
    Evansville IN
    did all of these trucks have the same color interior?
  8. Kens 50 PU
  9. Brian
    Brian Member
    Tulsa
    Could it be seacrest green? That was the only other green on trucks. I think primer was usually black, but maybe not.
  10. henry51
    henry51 Member
    Evansville IN
    Thanks for the chart looks like It could be seacrest green.
  11. vwnate1
    Nice truck ! Love those old DeSoto bumpers , they were the Bees Knees many years ago....
