Pilot Bushing removal
Discussion in '1947-1954' started by KentC, Sep 27, 2006.
  1. KentC
    KentC Member
    Lubbock Area
    I tried Nate's suggestion on removing an old pilot bushing. You load the hole with grease then use a wooden dowl, along with a hammer to force out the bushing, utilizing hydraulic pressure. I did not have a wooden dowl, so I used a same size 3" bolt wrapped in teflon tape, then whacked it with a hammer. It worked like a charm. Please forgive for doubting.
    kentc
    It Works !
    Wierd , isn't it ? .
    You can also whittle down a bit of old broomstick ;)
    There's lots more of these simple , olde tyme tricks I'm still learning , thanx to good folks like you all .
  3. brit 50
    brit 50 Member
    Essex England, the motherland
