6-lug disc rotors
Discussion in '1960-1966' started by Ebon Hawk, Sep 30, 2006.
  1. Ebon Hawk
    Ebon Hawk Member
    I'm sure this has been answered somewhere, at some time, but I've scoured the forums for it, and can't come up with anything...
    I'd like to convert my front brakes to disc, but I'd like to retain my current 6 lug rims... I really like them. My question is, if I were to swap out the entire front end from a newer model Chevy, say anything '73 thru '87, is there a place I can obtain 6-lug rotors for those spindles? I have access to a good parts truck, that would have everything I need to swap over as far as front suspension, but it's got 5-lug rotors on it.
    I've seen the disc conversion kits here on CPA, and had to wonder, can you buy just the 6-lug rotors that are for that kit by themselves? I'd imagine that eventually you'd have to replace the rotors, especially if this is a daily driver, and they'd have to be available somewhere. Also, if these 6-lug rotors ARE available, will they work with stock Chevy spindles?
  2. drabo
    drabo Member
    Patrick AFB, Florida
    CPP has what you need. I would reommend that you spend the extra bucks to get the disc brake spindles. Their brake set ups are based on I do beleive 73-87 Chevy half tons.
  3. verdell
    verdell Member
    Columbus, MS
    They're right...I ran into the same situation with my '60 shortbed 1/2 ton..I wanted disc brakes with my original 6 lugs. Ordered everything from CPP, 2.5 inch drop spindles along with 6 lug disc rotors. It's been doing great for almost two years now but unfortunately CPP's customer service kinda sucked... #1 they didn't want to honor the advertised price #2 they sent me a bad front brake caliper (leaked) #3 they wanted to charge me to return the caliper. Other than that, my 6 lug front disc brakes work okay. Next I'll be putting disc on the rear. I've got some '82 cadillac rear calipers that are in great shape along with the brackets. Just need a few more parts and I'll be set.
  4. dvalentine
    dvalentine Charter Member
    Sacramento
    THAT could never be said about Early Classic Ent. ( http://www.earlyclassic.com ) Their front end kit is VERY complete. I used their six lug rotor kit 4 years ago and it's still under there. The kit went in in less than 8 hours on my panel.
    Customer service is the best in any industry. I pestered them with pre-sales phone calls for months and they were always friendly and knowledgeable.
    Val
  5. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    Disk Brake Conversion
    I just wen to that website link and couldn't find a kit for an AD truck only for 60's model.:mad:
  6. 66 KUSTOM
    66 KUSTOM Member
    SALEM OR
    D Val Is Completly Correct, I Have Done Many Lowering And Brake/suspension Swaps And I Havnt Found Any Easier Then Early Classics, Exellent Help At A Very Good Price.
  7. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    6 Lug Disk Rotors
    Okay, thanks guys, I'll check it out. I'm sure there are a few companies / suppliers with conversions.
  8. dvalentine
    Sacramento
    Craig,
    Check out places like Jim Meyer Racing, Fat Man Fabrications, or No Limit Engineering for your 49.
    They all supply a weld-in crossmember and components that gives you independent front suspension, disk brakes and rack and pinion steering.
    Val
  9. cmkruse
    cmkruse Member
    SUNNY FLORIDA
    6-Lug Disk Rotors
    Thanks Val, et al. I'll check the other suppliers you mentioned.
  10. bluehaze52
    bluehaze52 Member
    TRY CONTACTING WWW.LMCTRUCKS.COM , THEY SELL COMPLETE CONV . KITS FOR WHAT YOU ARE WANTING . THEY ALSO WILL SEND YOU A SALES BOOK WITH ALL KINDS OF PARTS AND ACC. FOR YOUR YEAR MODEL .I HAVE HAD GOOD LUCK WITH EVERYTHING I HAVE ORDERED . AND TERE GREAT TO DEAL WITH.
  11. dcsi5919
    dcsi5919 Member
    Kansas City United States
    You can also try: www.bowtiebits.com They have a complete disc brake conversion kits, including 6 lug spindles, disc, rotors, etc. for a complete installation.
    Tony
  12. geoking
    geoking Member
    wheel size?
    What wheel size do I need when using this conversion? thanks
    george_king@jabil.com
  13. dvalentine
    Sacramento
    I used 15 inch old-school chrome reverse rims. They JUST fit.
    To get better braking performance though, I'd recommend 16 or 17 inch AND slotted like Ralley Wheels have. The disk / rotor combo works better when there is air circulating around it. A 15 inch closed rim dosn't allow a lot of room for air to cool the brakes during hard panic stops.
    Val
