I'm new
Discussion in '1955-1959' started by meanirishmofo, Oct 8, 2006.
  1. meanirishmofo
    meanirishmofo Member
    Hello, I'm new to American vehicles (VW Guy) and just aquired a 56' GMC and I want to lower it a tad is there any good web sites out there? I searched the threads first with no luck. Thanks
    Is that an English or a Metric tad?
    Cheapest way is to remove one or two leaves from each spring. I took out the 2nd and fourth counting from the bottom. Dropped my front bumper about an inch and a half.
    You can buy mono-leaf springs that will take your truck down a couple of inches and reversed eye mono-leaf springs that will go an inch or so more. May induce bump steer. May bottom out on the rubber frame bumpers when you hit a bump.
    Some one like Eaton can build you a stock spring pack with a reversed eye, which would drop your truck about 1.5" and still maintain the characteristics of the stock spring.
  3. meanirishmofo
    Thanks Bill, I found the Brothers Truck Parts site last night and I bought a Truck mag this morning. I'm pretty stoked about tinkering with the truck. I'm pretty used to driving my bug so I will probably go into shock when I have to fill the tank. The 472 Caddy motor in it will pass everything but a gas station.
  4. cosmo1957
    cosmo1957 Member
    Cambridge Canada
    Why would you lok at Brothers?
    These guys have everything they do as far as I know and they are cheaper?
    just wondering? :confused:
  5. meanirishmofo
    I did not see any spring kits on this site, Only IFS kits?
