52 chevy 3100 door hinges
Discussion in '1947-1954' started by rdh3500, Nov 1, 2006.
  1. rdh3500
    rdh3500 Member
    any know where to get door hinges for 52 3100
  2. Kens 50 PU
    rdh, I looked through several of my catalogs and the only one that showed that they have them is bowtie bits. their website is www.bowtiebits.com BTW welcome to the forum.
  3. Kevin's 48
    Kevin's 48 Member
    Tn
    It used to be that various vendors would take your old hinges and drill them out and re-bush them , fit new hinge pins and return better than new.....
  5. rdh3500
    rdh3500 Member
    thank you for your help. maby now i can hang the doors. i bought the truck without hinges and its hard to do bodywork without everything lined up.
    Warning ! Warning ! Warning !
    Be aware these trucks had extremely poor jig work when they were built so don't expect the doors to both look good (gaps & alignment) and close well ~ you'll get one or t'other but rarely both .
    Best bet is to tack weld the doors in place _before_ you remove the cab off the chassis , then invert it and repair floors , dash etc. and then once it's done , cut the welds and work the doors as a last item . this helps the cab retain its shape as you're working or welding on it .
    The guy in my shop who has a hot rod '49 , has terrible door fittment , esp. the passenger side door as it has a big gap between the 'A' pillar and the leading edge of the door , this is the # 1 most common fault in AD trucks and it will leak if the truck is left out in the rain , his $60,000.00 + show truck obviously never gets wet unless he's washing it but it drives him crazy nontheless ~ he removed the door skins and re-worked the inner door's frame as best he could then re-attached the skins but it's still not as he'd like it .
    Anyway , I wish you luck with it , I just adjust for easy opening and closing where no SLAM ! is needed and let the reveal mounding line up where it may , that's how GM did it .
