horn setup??
Discussion in '1947-1954' started by sloromon, Nov 5, 2006.
  1. sloromon
    sloromon Member
    Phoenix, AZ
    this is the horn setup on my grandpa's truck. thought this was an interesting way to mount them. anybody know if this was a standard thing or not?? i thought there was one horn that mounts near the carburator somewhere??:confused: and does anybody know about getting brackets for installing horns? i have horns, but there wasn't originally any on my truck. looking for a way to mount them. do i have to fabricate something???
    jon
  2. federale
    federale Member
    Washington C.H.,Ohio
    Most horns are mounted on the driver's side inner fender well. HTH
  3. brit 50
    brit 50 Member
    Essex England, the motherland
    DeLuxe Acessory Horns
    These are not the GM truck acessory horns but I bet they sound neat ! this typ of ' ram's horn ' design makes for a nice loud but pleasing tone .
    The relay is _critical_ as the amperage draw of two horns will burn up the contact slip ring in the steering wheel quickly .
    As mentioned , you can hang these unde the upper baffle plate to hide them and make more " toot " go outside and less echoing 'round in the cab with you .
    I'd keep 'em .
