60 chevy 235 to 305 change
Discussion in '1960-1966' started by 60 LWB stepside, Jul 30, 2006.
  1. 60 LWB stepside
    60 LWB stepside Member
    I was wondering if anyone might know where i can find out how a v8 mounts into the chasis of a 60 chevy. I am trying to swap engines from the 235 to a 305 but cant find any referrence to how the origianal factory mounted the V8 in the chasis. PLEASE HELP!!!!
  2. 62 short step
    62 short step Member
    Greenwell Springs, La.
    In 60-62 they had a mount that went from frame rail to frame rail, looked like a horse shoe. My 61 is like that. I'll try to get you some pics of it. Jeremy
  3. 60 LWB stepside
    thank you i would greatly appreciate that and what of the back of the engine does that engine use the same bell houseing to mount it in the chasis
  4. dsu6069
    dsu6069 Member
    235 To 305
    No,
    Unless Your 305 Is Of The Same Era As Your 235 They Won't Bolt Up Gm Made A Early Block With A Narrower Bolt Pattern I Think They Changed Around '64 If You Are Looking To Go Automatic You Should Try A Place Called "advanced Adapters" Even If You're Not They Might Have A Adapter To Goto Late Model Blocks To Early Model Bellhousings This Will Enable You To Use The Original Bellhousing Cross Member.
