Expensive boat anchor
Discussion in '1947-1954' started by coilover, Dec 25, 2006.
  1. coilover
    There's an old expression that says if your not failing your not trying. I must really be trying on my 302 Jimmy OHC project but a little high school trig would have helped. Here it is at the bottom of the scrap pile, note no pushrod holes, and you can probably see that the valves couldn't open very far without crashing. Oh well, like I've said before, when you get to feeling perfect just try to walk across that pond just outside the door. So far I've sunk everytime.
    Dang ! an aluminum cylinder head ?! keep up the good work , Rome wasn't built in a day .
  3. brit 50
    brit 50 Member
    Essex England, the motherland
