my stuck engine
Discussion in '1947-1954' started by tom c, Oct 12, 2005.
  1. tom c
    tom c Member
    I tried for several days to get the engine in my "new" 54 truck unstuck. I finally decided to pull the head & see inside. The cylinder bores & piston tops look good . The piston tops look practically new . The piston tops are stamped "STD" . That probably indicates replacement pistons , right ? Factory pistons were not stamped , were they ? The reason the engine was stuck was not a piston/cylinder problem but appears to be a lifter/bore problem . Mice had gotten inside the valve cover as the oil cap was missing . They had carried cotton , from the seat ,no doubt & built a nest about the middle of the head . The mouse pee & droppings had gone down around the pushrods & got to the lifters.They all seem to be stuck . I plan to spray each one & try to free them . Any suggestions and/or words of encouragement will be appreciated . Thanks .:)
    RE: Penetrant
    Skip the Gibbs etc. and go to Kano Labs in Tn. and buy some " KROIL "
    it is , hands down , the best penetrant Ive ever used .
    Yes , you have replacement pistons , if it looks good consider buttoning it all up to see how it runs once you've gotten it loose .
    Vacuum out all the dust and mouse house before adding penetrant...
    Look closely at the feet of the lifters , if pitted you'll need to look closely at the cam lobes , grovves or pitting there means new cam time....
    Add a magnetic oil drain plug or put a cow magnet inside the rocker box _NOW_ .
  3. tom c
    tom c Member
    RE: Penetrant
    I found that my oil pan was full of water . It appears the water had just recently gotten in . Possibly just before I bought the truck . We had several days of heavy rain . The previous owner had the truck covered , but outside & the hood center strip was off the hood . Im guessing rain went thru the seam in the center of the hood & got into the engine . Although the weights on the crankshaft & the strainer part of the oil pump had started to rust , the two rod journals & bearings I have checked look good . Maybe I am in time to save the engine .:)
    RE: Cleaning Bearing Journals
    Prolly so , just clean clean clean and then oil everything to prevent future rust .
    If you find anything on a bearing journal you don't like the looks of . simply find some " Crocus Cloth " and use that to polish the journal , flip a strip of it over the journal then grasp the ends and pull it back & forth untill the journal is clean and shiny , rotate the bearing 90* (1/4 turn) and do it again , repeat untill you've polished the journal four times , getting a different 90* each time with a bit of overlap and _DO_NOT_ polish bearing journals with anything else ! . you'll kill them . very important .
