Gas tank sending unit test
Discussion in '1947-1954' started by Chiro, Mar 5, 2007.
  1. Chiro
    Anybody know what the resistance range in ohms that the sending unit is for the gas tanks in these old trucks. My unit is out, just having the tank boiled out and want to test it before putting it back in.
    I know that the TF trucks use a 30 ohm full, 0 ohm empty sender. I think the ADs are the same.
  3. Kens 50 PU
    Same on the AD's.
  4. Kevin's 48
    Kevin's 48 Member
    Tn
    Make for sure that you drag the float real slow and look for any breaks in the ohm readings. You don't want it to read full and empty correctly then not read in between wrong.
