216/ rpm's
Discussion in '1947-1954' started by 52stake, Mar 15, 2007.
  1. 52stake
    52stake Member
    I have seen a few comments abouts high RPM damage on the 216.
    Just how tight is to tight. My door plate says 85 hp at 3300. I know hp drops beyound that of course, but what is safe.
  2. Kens 50 PU
    I refuse to answer this question!
    Because Nate will kick my butt! (But in my opinion, if the 216 was not the best inline 6 chevy ever made, why did they use it for for long?) It's a dependable motor (even though it was babbetted and might have 5 lbs of oil pressure). Any well maintained engine is dependable (as long as it is run as designed). It is the longest running inline 6 of anything that chevy ever made. Damn, that was fun, now I will let Nate give you the straight scoop! Maestro, if you please!
    216 RPM Vs. Engine Life
    Yup , it's a darn good engine allright ~ I recall old ones out in the boonies that never , _EVER_ got any attention untill they wouldn't start or stopped running and this was on crappy non detergent oils and watery low Octane gasoline too .
    Anyway , there's basically two failure points on the venerable 216 C.I.D. Chevy Babbit Pounder engine :
    You can exceed the oiling capability of the engine and it'll burn out a rod (the good news is : I know of some that still are in use 25 years later , rods banging away)
    Or , the connecting rod will fatigue and snap off , right below the wrist pin and this is a serious failure as the flailing rod most often then punches a big hole through the side of your cylinder block .
    So , I'd say keep it around 3,000 RPM's on the freeway and do keep on top of the maintenance ! this means fresh oil changed whilst hot every 3,000 miles or at least three times a year , check and adjust the valves dwell & timing too , this all means the engine runs smoother and less stress .
    All you needs do is : get a swell/tachometer and cobble up some long leads , run it on the highway once so you'll know at what road speed you're doing 3,000 RPM and then just don't go any faster than that . simple .
    I knmow there's one lister here who _fully_ blanced and blueprinted his 216 when he rebuilt it and he goes about 3,4000 RPM's IIRC , I'd never , _ever_ do that .
    Didja know ? 216's tore up the dirt tracks in thier day.....
  4. brit 50
    brit 50 Member
    Essex England, the motherland
    Only tore them up cos of the rods hanging out the bottom of the oil pan!
    ________
    GRANNY HAIRY
  5. 52stake
    52stake Member
    Yes, Nate I did know that. Heck there's a fellow out here that drags a 51 chevy sedan with a hopped up 216. Once upon a time I had a 50 1/2 ton throw a rod out the side of the block. I changed the oil, tied the rod off to the strut, stuck a rag in the hole and drove her for months. Didn't idle worth a hoot.
    Wayne
