some random bolts-
Discussion in '1947-1954' started by sloromon, Mar 15, 2007.
  1. sloromon
    sloromon Member
    Phoenix, AZ
    -which are loose, and i'm not sure what they're for. i tried to tighten them, but they just turned and turned. also, they're covered in oil. probably another problem all together, but i thought i'd ask. help!! thanks,
    jon
    Looks Like
    Front motor mount bolts , you'd better slip your hand up over and feel for the other end turning so you can tighten them up , the one with the square washer in the very last pic appears to be moving over 3/4" and that's _very_ bad , can crack your crossmember....
  3. sloromon
    sloromon Member
    Phoenix, AZ
    thanks! i'll get on it.
    jon
