Trasmission oil entering
Discussion in '1947-1954' started by KentC, Apr 16, 2007.
  1. KentC
    KentC Member
    Lubbock Area
    I have the plate off the floor board, have just put in a rebuilt transmission, and noticed a screw/bolt hole toward the rear of the transmission. It is a 53' with a 235 engine and 3spd transmission, the little one. Before now, I had put the 80W oil in the side hole, using a tube and a funnell. But it looks easier if I use the top hole with a funnel toward the back of the transmission, if that is its purpose, then use the side hole to determine when it is full. Comments please. Thank you.
    KentC
  2. 54chevtruck
    54chevtruck Member
    West Chester,PA
    I am not quite sure which exact plug you are speaking of ? Try posting a photo. The one plug I do know of is the bearing support retainer plug which is located in the rear tail shaft housing. I do not think you should be taking that one out especially to fill the transmission. Nate ?
    If you're tlking about the plug on the center top of the U-joint ball , yes you can use it as a filler but it'll take a long time for the gear oil to slowly seep through the output shaft's bearing and into the tranny proper....
  4. KentC
    KentC Member
    Lubbock Area
    Transmission oil filling
    I looked in my manual, should have from the start. It is the "bearing support retainer plug" I have been looking at. I think I will not fill through there. Thank you.
    KentC
